Board index Peugeot RCZ Newbies New 200 Owner (finally!) - Bedfordshire
Introduce yourself to the forum here. What do you drive and what have you ordered?
OkeyStokey Regular
Thanks for that Ian.
Did you happen to take any photos of screw & clip location. I think a "how to" would be really useful (unless it has already been done)?
This is the state of mine, which is why I would like to tackle it, but I don't want to damage anything in the process.
beaks User avatar
Kudos: 42
I don't but I think there's 3 screws (torx) and a couple of plastic clips. The plastic clips you need to get a small screwdriver or pick to pull the centre pin out and then you can remove them.
Pretty sure you also need to remove the cover for the rear fog light and reverse light as well - this just pulls off.
Once this is done you should be able to unclip the exhaust clips. These are bolted onto a bracket which can be removed allowing you to clean them easier.
Your tips look no worse than mine did so with time you will get there! Just be patient... like I said getting some 0000 wire wool is essential and providing you don't go mad won't damage the chrome.
Cheers,
Ian B
@teambeaks
Take a look here https://www.youtube.com/watch?v=q9XTn9Nwfp0 if you want to know how to remove that thing
Kudos: 556
After watching the guy in that video struggle to remove the rear diffuser all I can say is good luck! lol
A few pics of mine when I removed it to put quads on.ImageImageImageImageImageImageImageImage
OkeyStokey Regular
Well, thanks for the info everyone.
I was hoping the tips would come out without having to remove the diffuser, but having looked at that video, it looks like a deal breaker for me!
I might just have to see how cleaning in-situ would work.
I've had mine off, easy enough job.
I'm a seasoned fiddler though :D
beaks User avatar
Kudos: 42
Seriously - I'm no master technician (by a long way) but it wasn't a massive ballache for me... no more than 15 minutes if that... I think that chap on the video was building up his part a little!
Cleaning in situ will drive you mad.
It's a few screws, a few clips and a few tugs (so to speak).
Give it a whirl.
Ian B
@teambeaks
Kudos: 588
I did mine on the car (before having custom quad fitted) no problem just need something soft to kneel on then loads of autosol and some foam wet & dry sanding pads.
Kudos: 1483
You just need a drill, some polishing cones and some good metal polish and a little bit of wet and dry and mobs a good ‘un !
Before
During and After
OkeyStokey Regular
Well, after the peer pressure! (just kidding).
I had a go at removing them and had a good and bad experience.
The good
The 3 X T27 bolts are easy, the 2 X plastic clips are a pain but not terrible to remove (especially with a spudger/mobile phone repair kit).
Removing the diffuser was quite tricky where it is close to the tips. It almost felt like there was a screw or clip still there, and I was sure something would break. However, I finally removed the diffuser (don't forget to unclip the wiring connection to the lights). which allowed the tips to slide forward away from their clips, and out.
I cleaned with wire wool, autosol, and a buffing wheel on a dremel. Slight pitting on the underneath, but almost as good as new.
The bad
I cannot for the life of me get the diffuser to go back home properly. The problem I have is that the platic bodywork above the diffuser is very flexible, so when you apply pressure to fit the clips in, it just bows forward.
The annoying thing is that the diffuser covers the area you need access to to stop it bowing forward. :evil:
CLEAN TIPS.jpg (181.62 KiB) Viewed 730 times
Here you can see the clips not engaging.
The other problem was the light cover clip has snapped off in one corner with all the wrestling so it now droops.
Well at least the tips are shiny!
Kudos: 588
Before I changed my defuser to a carbon fibre one, the cowl under the light broke both tabs (crap idea) but a couple pieces of good double sided tape sorted it :thumbup:
Return to Newbies
