Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics 380-360 DEGREE LED EXTREME POWER 5 WATT
Interior, exterior and warning lights
Post Thu Aug 21, 2014 10:08 am
jactac User avatar
Kudos: 509
Ok so a while back some members including myelf fitted the 380-360 DEGREE LED EXTREME POWER 5 WATT bulbs as DLR's, while others went with the 380 Ultimate Canbus 92 SMD LED.
Personally after trying both bulbs I found the 380-360 Extreme a bit brighter as a DLR and easier to fit, however 2 years on and they have started to go faulty.
Basically one is stuck in DLR mode and the other in side light mode.
I'm not actually 100% sure that it is the bulbs or that the cars lighting system has decided to reject them after 2 years.
I find it a bit odd that both should play up at the same time, or pehaps I've just not noticed that one went dodgy before the other ?
Anyway, I've searched high and low for these bulbs and just cant find them anywhere :eusa-think:
The 380 Ultimate Canbus 92 SMD LED is available but I wasnt that impressed with it when I tried it out, so want to stick with the 380-360 DEGREE LED EXTREME POWER 5 WATT if I can find a supplier.
Has anyone who fitted the 380-360 DEGREE LED EXTREME POWER 5 WATT in the past replaced them lately ?
And if so where did you purchase them from ?
I've tried the original retailers and others, but they just list the 380 Ultimate Canbus 92 SMD LED now :thumbdown:
Any advice appreciated :thumbup:
I'm going to remove the bulbs and swap them around to see if the fault still occurs, if so I will then know if it is the bulbs or not .
RCZ 156 GT
Opal White,
NG4 Sat Nav, Latest firmware/Maps/Speed cameras
Interior Sport Kit,
Onyx Black Solstice 19's,
Front RCZ Splitters
Phillips H7's Diamond Vision/Phillips X-treme vision
380/360 Led DLR's
Paint & Interior leather protection
Kudos: 380
Swapping sides would let you know if its the bulb or car.
jactac User avatar
Kudos: 509
Yeah this was my thoughts also.
I find it odd that both LED's should go faulty at the same time, but maybe I've just not noticed one go faulty before the other. :eusa-think:
If I cant get hold of the 380-360 DEGREE LED EXTREME POWER 5 WATT, then I may just put the original OEM bulbs back in as I didnt think the alternative 380 Ultimate Canbus 92 SMD LED was much good as a DLR.
RCZ 156 GT
Opal White,
Interior Sport Kit,
Front RCZ Splitters
380/360 Led DLR's
Return to Lights & Electrics
